| stuartwood |
Nov 4, 2007 03:17 PM |
1995 C220 Electrics intermitent lights in dashboard?
When I switch the car on the lights behind the round air fan dials start flickering at high speed. As soon as I switch the lights on the go off and no flickering. Also all the other lights go off behind the centre console instrument panel. The fan temperature also gets very hot even when set on cold! I suspect this is a loose connection as when I go over a bump at speed it intermitently resolves the problem. Any thoughts???? Should I take the centre console out and take a look or does a mechcanic/electrician need to take a look?
