02 c230 alt bat light malfunction
Old Jul 11, 2009 | 03:49 AM
02komp's Avatar
Default 02 c230 alt bat light malfunction
battery load tested fine .had 14.0v at idle. esp no on as well ,bad diode in alt ? please advise thank you
Old Jul 20, 2009 | 08:42 PM
aviteck5's Avatar
I would suggest that you do a a alternator load test. Sometimes you can have the pressure (or voltage), and no have the flow (or current). Does the car shut off do to insufficient power, or is it just a battery light on.
Old Jul 21, 2009 | 12:12 PM
02komp's Avatar
Default thank you
started checking , main feed wire ((blue ) from alt plug was broken , wasnt feeding the other circuits properly.
Dehaven
Feb 17, 2021 11:56 AM
zigyrat1
May 14, 2009 06:12 PM
acpeeps
Oct 24, 2005 10:48 AM
