01 C240 no start
Old Jun 22, 2007 | 07:40 PM
TJS_C240's Avatar
Default 01 C240 no start
I've got an 01 C240 with ~ 91,000 mi. It will crank over fine, just won't fire. Can someone tell me where to start looking for problems, or am I at the mercy of the dealership?
Tom
Old Jun 22, 2007 | 07:53 PM
joyanlili's Avatar
Default RE: 01 C240 no start
YOU MIGHT HAVE A BAD CRACK UP SENSOR........ OR SOME TIMES THERES ONLY A MUD OR DIRT ON THE SENSOR...... TRY TO LOOK IF THERES A DIRT......CLEAN IT AND GIVE IT A TRY....IF NOT YOU CAN CHANGE THE CRACK UP SENSOR
Old Jun 22, 2007 | 09:24 PM
TJS_C240's Avatar
ORIGINAL: joyanlili
Sorry, not sure where or what this sensor is. Can you tell me where to find it?
Tom
Old Jun 25, 2007 | 09:30 AM
grapes's Avatar
Lets work on the fuelsystem tofirst trouble shoot your problem. First locate your fuel-pump fuse, my 03-C240 is in theleft hand trunk side panel #4position.Find it,remove it and check to see if it is OK. Turn key to the ignition on position justbefore the starter positon, go back to the fuse and install it. you should hear the pump operatefor a few seconds. That should tell you if your fuel pump is ok.,
The Crack valve ",I think," is like a Finigan pin which are not real parts. so don't waste your time.
Old Jun 25, 2007 | 04:31 PM
Neon's Avatar
ORIGINAL: TJS_C240
ORIGINAL: joyanlili
Tom
I'm pretty sure joyanlili meant the Crankshaft Position Sensor. They've been known to go south on the V6/V8 motors.
dewk6600
Dec 12, 2016 01:33 PM
tabourj
Nov 26, 2006 04:37 AM
jfe105
Sep 8, 2006 01:58 PM
washoor
Aug 28, 2006 11:53 PM
EuroKRN
Dec 27, 2005 02:14 PM
