Mercedes AMG Class All AMG Models.
No air on drivers side
Old Jun 13, 2005 | 11:50 PM
AMG4REV's Avatar
Default No air on drivers side
I need your help. The drivers side air conditioner is not as cold as the passenger side. I can set both temp to “Auto” for both driver and passenger side and the air is much colder on the passenger than the drivers side. Has anyone had this problem before? What could it be?
Old Aug 3, 2005 | 02:32 AM
MBZTech's Avatar
Default RE: No air on drivers side
Under the hood on the passanger side there should be a green vacuum line that runs through the fender and behind the right front wheel lining. Check to see if you have a vacuum leak anywhere in that line. That green line controls the driverside AC cooling. Iv seen many times where that line has been pintched or cut open. Repair the line and it should work. Good luck
Old Aug 3, 2005 | 08:48 AM
sleepwalker's Avatar
check the freon or pressure if it's enough.
14 to 16 bar is good.
leemusmeers
Sep 1, 2008 04:23 PM
mb560sec
Oct 1, 2005 12:34 AM
kevinrea
Aug 10, 2005 01:48 AM
jbsteven
Jul 9, 2005 09:27 PM
benzgirl
Mar 8, 2004 12:17 PM
