A different ?
I was looking online and found a 2002 C32 that was about a few thousand more than a 99 E55 I asked about earlier. Can the C32 compare to the 99 E55? Which one would be most likely relieable as far as common problems with each model? Thanks
RE: A different ?
i always prefer the E-Class than C-Class.
RE: A different ?
ORIGINAL: sleepwalker i always prefer the E-Class than C-Class. That's what I was thinking...but what about the supercharger in the C32? |
RE: A different ?
yeah, that's 6 cyl kompressor against e55 8 cylinder.
your choice. |
RE: A different ?
C32 is faster and easier to mod.
RE: A different ?
More less its what size car do u you to drive?
RE: A different ?
ORIGINAL: sleepwalker yeah, that's 6 cyl kompressor against e55 8 cylinder. your choice. I know, but the C32 is a supercharged V6 that has about the same HP and 0-60 times. This is for 1998-2000 E55 and 2002 C32. That's about all I know. These things are so close, so which do I go for? That's the real question. Thanks |
RE: A different ?
ORIGINAL: mbz300sdl More less its what size car do u you to drive? |
RE: A different ?
ORIGINAL: blackbenzz C32 is faster and easier to mod. What can you mod on the C32, that maybe cheaper on not done to the E55? |
RE: A different ?
C32 is s/c. All you need to do is get a ECU tuning and a bigger pulley and you will be over 400hp easy. E55 requires alot of work since its N/A. C32 will outhandle the E55 too, especially if you get coilovers like Bilstein PSS9's or KW's.
