Mercedes AMG Class All AMG Models.
AMG aftermaket filter
Old Sep 26, 2005 | 01:45 AM
AMGkid's Avatar
Default AMG aftermaket filter
I just fitted my 1996 C36 AMG with a new ASB cone shaped racing filter which sits right next to the engine, completly by-passing the factory air box. Even though I have slightly more power at higher RPM's, I have lost off-the-line torque, and am concerned about how hot the filter gets. Does the factory air box/rectangular filter set up create some kind of special air flow or pressure to the engine I should know about?
Should I put a rectangular filter back into the box the way it is from the factory, or customize it by completly removing the box and extending the cone filter where more cold air can blow. And if I did 'customize' it, would this make any significant difference in my power/performance.
Thanks for your input
Old Feb 9, 2006 | 02:34 AM
jnolte's Avatar
Default RE: AMG aftermaket filter
i would add on extra piping to go into the bumper/fog light area. This is much colder air and then your intake isnt sucking in hot engine. You could also build a heat sheild out of metal. If your just sucking in hot air, your better off with stock air box. After hours of driving the heat soak will slow down your car more
Old Sep 13, 2006 | 05:49 AM
Dr_Joe's Avatar
Beware ! Cotton gauze/oil type filters have been known to cause premature mass air flow meter failures ($$$)
StickyBenz
Feb 1, 2012 06:24 PM
dablk1
Mar 30, 2009 04:10 PM
parasuco
Mar 13, 2009 02:21 PM
Lhaitzss
Mar 5, 2007 10:44 PM
Bimmer
May 18, 2004 10:48 PM
