02 Mercedes s55 amg
there are brackets that slide tward the front wheel. near the side marker lamp. you must first remove the wheel well liners. then loosen the screw/ its a small torx usually. then slide out the metal bracket it holds the bumper to the fender.
not really. just make sure the fender and bumper are pressed tightly together and then the bracket will slide back onto the 2 pieces sometimes you might have to force it on with a screwdriver. or lube up the bracket with some oil or vaseline so it slides easier then put the screw back in.
Armen
10-07-2005 09:05 PM
