K1 Motorsport HRE | BRABUS | Lorinser | RennTech | KLEEMANN | Carlsson | H&R | Bilstein | AMG | iceLink Pro | OEM and more.
Key/program
Old 06-17-2009, 05:29 PM
wiltonhenry's Avatar
Default Key/program
I purchased a spare key for my 2001 s500/the dealer said they can only program a key purchased from them for...300.00 any suggestions.....wilt
Old 06-17-2009, 06:52 PM
CONNECT A BATTERY CHARGER!!!! put the key in the ignition and turn to position 2. (2 clicks. go slow till the dash lights up) DO NOT TRY TO START!!!!!. You will see the red led on the key go on and stay on. You will see the light go out anywhere from 1 min to 6 hours later. Then you may start the car.
Old 06-18-2009, 09:25 PM
Default key program
How many amps on charger/can this be done without the charger/will the remote open the doors also
Old 06-19-2009, 01:07 PM
the new remote should open the doors since it is ordered by VIN. the charger need to be connected because the programming can not be interupted. (key in ignition) if it is the key will be no good. you can put a charger at 5-15 amps. This should be sufficent. like i said before, sometimes it takes only 5 min to program. It all depends on how the car feels that day
Old 06-19-2009, 07:59 PM
Default Key
Gotcha/thanks
ferg32
02-19-2009 10:09 PM
alghawas
08-11-2008 08:56 AM
jacksrbet
03-09-2008 05:14 PM
assad
06-11-2006 05:10 AM
xquisite
01-04-2005 02:12 PM
Quick Reply: Key/program
