Interior What have you done to the inside of your ride? Talk about it here.
shifter light bulb replacement
Old Aug 28, 2006 | 01:02 AM
MB420's Avatar
Default shifter light bulb replacement
Does anyone know how to replace the shifter light bulb in a 94 e420. I need to take out the center console wood but dont know how. please help.
Old Sep 30, 2006 | 01:07 PM
Syntax26's Avatar
Default RE: shifter light bulb replacement
I just did the shifter bulb on my '95 E420 a couple of days ago. Here's how:
MAIN thing to know is you have to get a wrench down there to loosen shifter retaining nut. Once you know this, everything else is cake.
Start: Top bezel (black plastic) - has two clips - top and top left - pry lose and pull up. Can't remove yet - shifter **** prevents this. Nex, jiggle the hard plastic module up and to the left - you're just trying to get it out of the way. Pull boot up - see the nut?
Put shifter into neutral - nothing to do with the transmission - better access to the nut with shifter straight up.
Loosen nut, remove shifter, thereby allowing top bezel and hard plastic assemby to be removed.
You'll now see the light. Easy, common sense to finish.
You can get replacement bulb almost anywhere - I got 'em at Advance Auto.
Jim
craigb
Dec 17, 2007 07:32 AM
MB420
Aug 29, 2006 02:15 AM
Vorpal
Apr 9, 2006 01:43 AM
snakoiler
Jun 24, 2005 09:43 PM
Paul
Jun 6, 2005 05:56 AM
