WIS Problem
Hi all,
i just got my WIS, then i installed in from wis\wisinst\setup, but after the installation, when i clicked on PM, some german words came out, saying: "Bilder werden nicht gefunden Falls sie nach nochmaligem Start nicht vorhanden sind, verstandigen Sie Ihren System-Administrator" then i clicked ok, and everything seemed to be in german. there's a name and password where i put admin and admin. although i installed it in english. Then there are 2 big blue "?" with the name notepad and wis. when i click wis, a german wis came out saying: Wirkung: Weiterarbeiten evtl. nicht moglich Ursache: Interner Datenbankfehler '11011' aufgetreten Abhilfe: Bitte informieren Sir Ihren Systemadministra the no ok, only "weiter" all is in german, and i try to click everything i could but just going any further. please advice me what should I do, I tried it on 6 computers and its the same. Thank you. |
RE: WIS Problem
it's not properly installed (database).
try installing from d2kinst folder. install it as a user and not server. program manager works fine. |
RE: WIS Problem
Try going into system through windows and to hardware. Uninstall the network card which is used for wis, also search your computer for a file called lan.id and delete it if it is there. Restart your computer and the network card will automatically reinstall. If you hold your tongue the right way as it reboots, your system should now work. ;).
