WIRING HARNESS
Old Mar 27, 2005 | 10:42 PM
thegirlilove's Avatar
Default WIRING HARNESS
Can anyone tell me the symptoms of a failing wiring harness for a Mercedes vehicle?
Thanks!
Old Mar 27, 2005 | 10:51 PM
sleepwalker's Avatar
Default RE: WIRING HARNESS
engine shaking.
hard start.
Old Mar 28, 2005 | 07:28 AM
Thanks Sleepwalker,
is there anyway to disable the security alarm feature on my 95 C280? and still drive the car as normal?
Old Mar 28, 2005 | 11:31 PM
your engine is 104 or 112?
you may bypass the starter relay for it is only that one which might be being dis-abled.
Old Mar 31, 2005 | 05:29 AM
I do not know what my engine 104/ 112?
Anyway sleepwalker, I diagnosed my car again via an indie workshop. The HTT/ or computer they used (i forgot the brand name) has indicated that there are "faults in the door circuit" but when wanted to extract the details, it states undefined.
Could it be that there are faulty wirings (or other possbilities) in the doors circuit be related/ connected to the rear view mirror and causing my intermittent starting failures (red & green lights)?
Old Mar 31, 2005 | 08:51 AM
the only cirsuit you got on your doos was the illumination lamp and the door switch.
the door circuit have nothing to do with the starting problem.
the door switch will either trigger the alarm or the interior light cannot function well on "door position.
Old Mar 31, 2005 | 10:22 PM
the door switch will either trigger the alarm or the interior light cannot function well on "door position"
so when the alarm is triggered, it means the alarm is being switched on so therefore the car could not be started and therefore the red/ green lights in the rear view mirror starts flashing alternately, telling you that the alarm is being activated ?
Old Apr 1, 2005 | 01:02 AM
yes, but there should be an audio alarm too (horn), and the side lights (visual) signal.
Old Apr 2, 2005 | 12:59 AM
  #9
Sleepwalker,
Is there a possibility to disable/ deactivate the built in alarm & central locking system in my 95 C280?
I would like to install an independant branded alarm & central locking system for my car
Old Apr 2, 2005 | 07:13 AM
  #10
it's not easy because of the design functions for engine control unit.
you see, everytime you insert the key on the ignition, the authorization code is replaced using random numbers.... and then is being stored on the engine control unit. it simply means that the key doesn't carry the same password throught it's life. it is changing everytime you use it, and it is being match with the control unit. for example "120000212854". both the key and the control unit should carry the same code.
now, the possibility includes replacing the control unit too! and getting rid of the RCL module.... and most probably the PSE also. it's just too much compare to just having the thing fixed.
vieuxscott
Jul 28, 2005 03:22 PM
cpiad2005
Jun 21, 2005 12:54 AM
thegirlilove
May 2, 2005 10:57 AM
francosrides4u
Aug 12, 2004 08:27 PM
benzgirl
Mar 8, 2004 05:29 PM
