will wheels fit??
Hi. Could anyone help?
I need to know if Mercedes Alloy wheels from an E300 Avantgarde(211) year 2003 with 16 inch wheels, will fit my E230 1997 saloon (210).Both have 5 Hole lug fitting.http://forums.mercedesclub.org.uk/im...s/confused.gif[/align] |
RE: will wheels fit??
should work for you. might want too double check the length of the lugs first and compare the lugs in one rim to the other rim to see if the stick out the same amount
Thanks for reply.
I am still a little confused. Can I ask you that if I have the bolts of the 211 wheels that I want to fit to my 210 & the offset and wheels fit, would I still require some additional fitment device because the fitting is uncompatible? Or are you assuming that I would use my original bolts on my wheels from my 210? These are smaller in length as shown in handbook. Thank you for help |
