where is my radio amplifier ???
Just purchased a '93 model 190e. The radio won't crank up [&:]. Have enough sound on full volume to know that some function of the radio works and have that sound in 4 speakers. Have replaced the fader switch without improvement :(. Am guessing now that it is the amp. Was told that the amp was an easy find in the trunk.
Can anyone help me with location and/or any other helpful advise on diagnosing the issue or even where to find such an animal if it needs replacement? Thanks a whole bunch :). |
RE: where is my radio amplifier ???
124 or 201?
How would I know whether it is a 124 or a 201 and what is the difference? The VIN# is WDBDA29D1PG063902.
Thanks. |
according to this, it should be on the rear... inside the trunk, right side.
on older model, it is under the rear seat, left side. 124 and 201 got different body. VIN WDB2010291G063902 Model 190 E 2.6 Chassis 2010291G063902 Engine 103942 12 080804 Transmission 722409 03 296762 Order 0 2 704 18856 Approx. year 1992 Lights BOSCH Wiper BOSCH Dealer United States (USA) (704) Interior mb-tex black (171) Paint 744 brilliant silver metallic (с 1991) 71 Unknown code Options 221 left front seat, electrically adjustable (с 01.11.1978) 222 right front seat, electrically adjustable (с 01.11.1978) 240 outside temperature indicator (с 01.03.1982) 250 Alpine radio set (с 01.07.1989 по 31.10.1993) 280 steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984) 286 luggage nets on front seat backrests (с 01.01.1962) 340 additional 3rd stop lamp (с 01.10.1989) 412 electric sliding roof with tilting device (с 01.07.1983) 420 automatic transmission, floor shift (с 01.01.1963) 444 tempomat (cruise control) and airbag (с 01.02.1980 по 31.10.1993) 461 instrument with mileage reading and english lettering (с 01.04.1990) 491 USA version (с 01.01.1963) 524 paintcoat preservation (с 01.01.1964) 543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978) 551 anti-theft warning system (с 01.11.1978 по 31.03.1998) 570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970) front folding armrest w202 - housing at front with armrest 586 Behr air conditioner, and electric window lifters (front and rear doors) (с 01.04.1970) 593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972) 639 elimination of first-aid box and warning triangle (с 01.08.1977) 640 15-hole light alloy rims (с 01.01.1990) 664 10 liters of fuel and mode of packing VE III (с 01.01.1979 по 30.06.1993) 803 Change of year of model, last figure shows new model year 814 active bass loudspeaker system (с 01.10.1989) 876 rear door contaCTS and lamp above rear window (с 01.07.1964 по 31.10.1993) 916 Unknown code [IMG]local://upfiles/1/C6507DAC3B7F4873920C824EB1D3BD22.jpg[/IMG] |
Info for a VIN Number?
Sleepwalker.
Where do you get the info from the VIN number. Is there a service online, or do you work for a dealer? Could you run a number for me? Tim Wheeler |
| All times are GMT -5. The time now is 02:42 AM. |
