-   -   Wheel swap (https://mercedesforum.com/forum/general-tech-5/wheel-swap-26773/)
c6vetteman Feb 4, 2008 12:22 PM
Wheel swap
Where can I find infoto see if2008 S550 standard wheels and tires will fit on my 2001 S430 ? I know the bolt pattern is the same - 5 X 112. But there is also a mention of a 43 mm off set!
wmercer Feb 4, 2008 01:04 PM
RE: Wheel swap
I use www.tirerack.com and compare wheel sizes and bolt pattern and offsets to different cars.
RichardM98 Feb 4, 2008 07:35 PM
RE: Wheel swap
Also, at www.mercedesshop.com in the wheels and tires subform there is a tire size calculator which will show you how much speedo error your replacement tires will give (if that matters).
c6vetteman Feb 4, 2008 09:30 PM
RE: Wheel swap
Thanks. I feel they will work. I used several types of calculators and think I'm Ok. Any more comments are appreciated.
