-   -   wheel change wont move now (https://mercedesforum.com/forum/general-tech-5/wheel-change-wont-move-now-33176/)
k4chu Nov 12, 2008 06:31 PM
Hi all. Newbie here, new to mercedes too. I have a 1996sl500 just changed to newer wheels 19" and put the car back on the ground and it wont roll but a few inches foward and backwards, does not hit calipers or anything else what could this be? Thanks Kevin
k4chu Nov 12, 2008 06:51 PM
RE: wheel change wont move now
Rear wheels only move a little fronts move fine, thanks Kevin
k4chu Nov 12, 2008 07:13 PM
Dont know if this matters but I do have to help the parking brake pedal up. Thanks Kevin
chassis221 Nov 12, 2008 07:58 PM
lug bolts are too long and are caught up in the E brake.. most likely
k4chu Nov 12, 2008 08:15 PM
Your right, I just got back in from the garage and that is what I figured out. thanks for the reply
chassis221 Nov 12, 2008 08:46 PM
if you were able to drive it and did break the Ebrake you could need a new hub assembly$$$
k4chu Nov 14, 2008 08:55 PM
No did not drive it when I felt the least resistance, I was unsure if the wheel would fit so I was being real carefull and listining as I backed up. I have ordered some shorter bolts now and should be on the road real soon. I still have quite a bit to learn about these cars, but they sure are nice. Thanks for the replys, Kevin
