-   -   Upper Guide Rail Pin Removal (Timing Chain) (https://mercedesforum.com/forum/general-tech-5/upper-guide-rail-pin-removal-timing-chain-23095/)
col190 Sep 9, 2007 07:16 AM
Any suggestions on removing the 2 pins of the upper guide rail? I need to remove the cylinder head to replace the gasket - these pins need to be removed (I think) unless I split the chain.
Haynes says pull them out, but there is no way these are going to be pulled out ...
Thanks for any help
Colin
1989 190 2.0L Carb (201)
