Tyres and wear
Hello all, hope you can help me, I have a 1998, C250 with low profile 18" Tyres on it. My problem is the rear tyres are wearing on the inside at quite a rapid rate. Could this be a tracking snag, or anything untoward????
Over-inflation would indeed wear-out the center of the tire.
Take it in for a 4-wheel alignment and that should do the trick.
Was it done since the new 18" went on the vehicle ?? I would almost bet that it wasn't.
Make sure you get a 4-WHEEL Alignment, because some alignment shops will only align the front-end unless you tell them.
