Turn Signals
Old Mar 9, 2007 | 11:14 PM
bcs1016's Avatar
Default Turn Signals
I have an 02 C320 and my turn signal on the front passenger side wont work and it is not the bulbs. I posted this in the c class forum as well and I am just really ticked off at this. Anybody with any info or similar problems would be great.
Old Mar 13, 2007 | 10:49 PM
kurt08's Avatar
Default RE: Turn Signals
have you check the connections? sometimes loose connections causes Mercedes turn signal not to work, or it could also because of some poor grounding system.. just give us an update regarding this issue.. good luck
Old Mar 14, 2007 | 12:32 PM
Mercedes Benz of FL's Avatar
If your ABSOLUTELY sure its not the bulbs
Then check your turn signal switch
Use a multi meter and check/test it.
Old Mar 23, 2007 | 02:02 PM
saleen1276's Avatar
there is a wiring update for the front turn signals on your car, it ivolves moving around a couple of wires and installing new ground wires..the problem is with the ones you have your not making contact in the connector, so even if you put new bulbs in they still will not work...the repairs kit part number is
2038260282 and you need 2 of them--go to your local dealer i think they only cost about 20 each..let me know if you have any q's
Old Mar 28, 2007 | 06:33 PM
02cl55's Avatar
Having the same issue on 02 cl55. Started with turn lamp, now the parking lamp will not turn on. Replaced the bulbs, still nothing.
Does anyone know if the ground is (hopefully) located near the bulbs themselves? Or is this a wiring nightmare needing to trace the wire for miles and miles???
Old Mar 29, 2007 | 12:30 PM
02cl55's Avatar
Found two main ground connections, removed and cleaned the metal areas... still nothing.
Swapped bulbs from left side parking light to rt side (side not previouslyworking), now neither side will illuminate??? Need suggestions
deegoode
Feb 1, 2018 03:34 PM
redtees1
Jun 20, 2011 03:13 AM
C280 wizard
Jan 20, 2008 04:34 PM
andrewgclifford
Jan 23, 2005 11:56 PM
steffen_fox
Aug 4, 2004 07:22 PM
