truck lock will not open
i have tried opening the trunk on my 84 300sd.
tried and tried. can hear i believe metal moving inside the lock? help! - francis |
mr forced induction - thank you for coming to my aid but could you please elaborate on cycling the lock and cycling the driver's door? simultaneously? - francis
thank you again mr forced induction. i will have to order a second key to perform what you advised. - francis
if i were to turn the key in the trunk lock to the open position the key is 'locked' and will remain in the lock, the second key i will need to cycle the driver's lock.
am i following your instructions correctly? assuming i read and understood you correctly and the vacuum is still not cooperating to open the trunk lock it appears i will have to remove the back seat and manually coax the lock to work. any suggestions? thanks again mr forced induction. for any mercedes owner to purchase a spare key the dealer will want your car registration and driver's license. i might receive my key from fort worth , texas in one day! about $23. |
