Torque Specs
I need 'em for my SL. Gimme, gimme.
Front rotors = ? Front calipers = ? |
RE: Torque Specs
10Nm for that small screw which holds the rotor.
[IMG]local://upfiles/1/80FC52F59D54465A93E2B26500331C7F.jpg[/IMG] |
RE: Torque Specs
[IMG]local://upfiles/1/71C0B84684C54ED49440310949285707.jpg[/IMG] [IMG]local://upfiles/1/EA6468102F544F29A606294FDF92EEF5.jpg[/IMG] [IMG]local://upfiles/1/517F2F1A57E94C5A9C41DFECE20BE2F4.jpg[/IMG] [IMG]local://upfiles/1/3BCF3D985EDA471DA1C3E17E33524818.jpg[/IMG] |
RE: Torque Specs
Thank you, sir. I can use all that info. And pictures, too. My favorite.
RE: Torque Specs
sleepwalker,
I took a closer look at the images. I don't see where the torque specs are for the rotors. Am I not reading something right? You're not saying ALL the rotor bolts are 10Nm are you? |
sleepwalker, ya there?
Do you have the torque specs for the rotors?
RE: sleepwalker, ya there?
but there's only one small screw that holds the rotor.
the wheel bolt will take care of the rest. |
Ooooh, okay. I see.
Thanks again. |
the wheel bolt is very safe at 150Nm.
you'd imagine he'd get Ft/lbs, since this is the US and our mathematic-scale is f---ed up. 10Nm is about 7.5ft/lbs or around there. Just make it hand tight, dont crank down on it with a rathcet...
Matt |
| All times are GMT -5. The time now is 08:06 AM. |
