Tach pickup source
I need help from the Diesel expert here.. Where is the source of the rpm pickup signal for W140 , 94 S350 Diesel? The eary model (w116) uses the pickup pin on the flywheel.. wonder the W140 still use the same technique. Thanks in advance. |
i have the same car with the same problem,did you fix it
