Suspension noise
Can anyone help? Whengoing over bumps in the road, the front drivers wheel feels slack and gives off a loud thud almost as if its loose. Have had a look underneath and appears to be nothing obvious. Would be most grateful for any advice.
RE: Suspension noise
common issues are sway bar bushings and the sway bar links. both have modified updated parts for noises. maybe also a bad wheel bearing?
Thankyou for advice.
I have an 02 4matic wagon with self leveling shocks. How do I bleed the system when I replace the shocks?
Check your lower ball joints and upper control arm bushings, if either are leaking that is probably your problem, we change them routinely.
