Sunroof
Car is a 300 TE and the sunroof will not close all the way. It gets about an inch from shutting then stops. Is there anyway to manually close the sunroof like on the 300's, and where would the motor be on my wagon?
Thanks Todd |
RE: Sunroof
you can manualy close it.
pry off the interior lamp lens and crank it using 6mm allen wrench. |
RE: Sunroof
Thanks again Sleepwalker![sm=icon_cheers.gif]
RE: Sunroof
on older version, you have to crank the motor located on the rear left wheel housing.
try to initialize it first by pulling the button, close it and then push back the button. |
RE: Sunroof
My bad, it is an 88.
