STARTS HARD WHEN COLD
1990 300SE < ONLY 40,000 MILES. PURCHASED OUT OF FLORIDA BUT NOW BACK HERE IN TULSA OKLAHOMA... SHE HAS A HARD TIME STARTING. STARTS THEN STALLS OUT. TAKES ABOUT 6-10 TRIES BEFORE IT FINALLY STARTS RUMBLING THEN IS OK. JACKIE COOPER IMPORTS SD IT WAS THE 02 CENSOR BUT $300 LATER ... SAME PROBLEM. APPEARS IT MAY NOT BE GETTING ENOUGH FUEL WHEN STARTING?
RE: STARTS HARD WHEN COLD
there is a cold start valve on it Mr. Bond.
it has to be enriched during starting especially if the weather is cold. pull it out and see if it's spraying. |
YUP! STILL SPRAYING >> TOOK IT BACK TO THE DEALERSHIP >>> AFTER THEY CHECKED ABOUT 50 DIFFERENT THINGS THAT IT COULD BE.... THEY FOUND 50 DIFFERENT THINGS IT WASN'T. STILL UNRESOLVED >>>>>
:eek:I'M GOING TO INSTALL A BLOCK HEATER FROM THE PARTS LINK > MBPARTS. THAT SHOULD SOLVE THE COLD ENGINE PROBLEM. CHEAP TOO! |
