speedo failure/abs,brake and brake wearl lites
1000 ohms is good.
between 900 to 1200 should okay too.
hold your breath because it seems to be a problem with instrument cluster itself or traction systems control module.
some basic checks that might do:
check alternator output
clean connector on kickdown cutout relay
there was a modification on instrument cluster because it was having problem with serial interface for traction system control module.
first check the the interface line to traction system control module:
pin number 7 and 1 should have less than 5 ohm resistance.
remember, only by actual thorough checking and diagnosis that the problem can be confirmed.
what i am telling you is only to give you an idea where to look at, and some hints.
Since my failures are interment and without a pattern (it could be stopped or driving and go away when it feels like it) can't I assume a problem with the ECU? I've check the connections and they all seem OK. I haven't checked the ECU state in itself.
Cheers...
Cheers...
The car visited the local MB dealer. It was impossible to interface with the MB tester. Codes included : 100 can: no reception from Diagnostic module. 072 Vss not recognized/ 107 dwell angle control at ignition output stage stop / 002 cc/ea actuator reoprt limp-home / 065 signal L5
I butterknifed the dash cluster out. I really cannot get the custer out. The steering wheel is in the way. there is no tilt or telescope. also, the car does not have traction control or arb. It only has abs.
the mechanic says he will needs a couple hours to figure it out. this can't be good. HELP? tryfunke
To answer sleepwalker's query:
alternator is checked oout to be fine 14.5 volts good sine pattern
where is the kickdown relay?
I have no idea how to get the cluster out
How much does refurb cluster cost and how do I correct for mileage?
How does one check the cluster? tryfunke
sleepwalker, I see you are online. Do you have any words of wisdom that could help me out of this mess. I have heard it could be the ovp relay. It cost 100dollars with a no return. Is there any way to test this relay with a ohm/volt meter? any other ideas? tryfunke
that was the cut out relay i mentioned earlier and on the right of engine compartment.
just see if the terminals are corroded (dirty) and try to clean first if it works.
there is a fuse on the top, check it too.
i will find the structural diagram of this relay later so you can test if you want.
I the cut out relay the same as the over voltage protection relay (OVP). ? I'm not sure about the location. Is it uder a plastic cover with the over electronic by the firewall on the passenger side. Forgive me, I don't know what side you drive on, but this car had a left side wheel. Are there any other grounds that get corroded amd can be cleaned up? tryfunke
Tests and so forth from a local expert who could put their hands on the car believe the problem is a faulty ABS module. Is a 96' one coded? Where can I get one for cheap? new is almost 700.
I am having the exact same problems as mentioned in your post. No speedometer, ABS, BREAK, breakpad warning lights are on. I tried replacing the instrument cluster, but still have the same problems. Have you found a resolution to your problem?
