Spark Plugs
Old Apr 18, 2018 | 01:09 PM
sergiojeff's Avatar
Unhappy Spark Plugs
Hey Guys,
Changed out the Spark Plugs on my 1999 SL 500 AMG it has 66,000. Did the left side first and it ran great, Next day did the right side and now the Engine is Rough Idling. When you give it
gas it bogs down and wants to die. Idling it runs fine. Give it gas and stops. Only thing I did was replace the plugs and One Coil that was showing Weak. Other then
that nothing else.
Please help,
Sergio
Old Apr 18, 2018 | 06:31 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! Are you able to pull any codes? This may be a good indicator of why the car is idling rough.
Old Apr 18, 2018 | 07:30 PM
sergiojeff's Avatar
Default Spark plugs
The code l got was an 02 Sensor code and misfire on 5,6,7,8 cylinder misfire
Old Apr 18, 2018 | 07:37 PM
sergiojeff's Avatar
Default Spark plugs
o2 sensor and cylinder misfire on 5,6,7,8
Old Apr 20, 2018 | 08:35 AM
Bigrob's Avatar
If this problem arose after you did the plugs, I am gonna guess that it could be some of the plug's "gaps" are off somewhat....or you didn't get the coil plug seated on the plug properly. Also could be replacement coil is not up to par. I don't think it will be anything other than what you worked on....too coincedental.
Old Apr 20, 2018 | 11:03 AM
sergiojeff's Avatar
Default Spark plugs
took all plugs out again bought new ones just in case. Checked gap all good. Plug wires pushed all the way to plug.
Old Apr 21, 2018 | 08:40 AM
Bigrob's Avatar
Did you try the old coil? It was running fine before you did this stuff, yes? Of course it could be a new issue, separate from what you did, that could have come up....
kzukowski
May 2, 2011 09:44 PM
jeffb
Jan 2, 2009 08:33 PM
azdesertDog
Aug 24, 2004 11:30 PM
joepaisley
May 24, 2004 11:42 PM
cmscott16
Jan 13, 2004 11:00 AM
