SL 450 timing question?
1980 SL 450 what is the timing spec? Sometimes blows black smoke, loads up any idea?
RE: SL 450 timing question?
0 degrees, or Top Dead Center with vacumme advance hose attached.
If this is a US model it should have a sticker in the engine compartment with this information on it. If you find such a stick then go with what it says. After checking the timing you should have the emissions tested as it seems to be running too rich. The air/fuel ratio could be off but there is no way to get it right without a tailpipe sniffer. Sam |
| All times are GMT -5. The time now is 10:38 AM. |
