secondary air pump failure
Wanted to post the following information to help save owners some money. I recently had my check engine light come on. Took my 2004 S500 (51,000 miles)into dealership. I was told my secondary air pump needed to be replaced. I spent nearly $1200 and picked up the car next day. When I looked at my receipt closer. I noticed they had replaced the relay $50 and a $5 fuse. I had previosly replaced the same relay for my Airmatic. I opened fuse box and noticed the new updated relay. I called my service advisor and asked him if the issue was the relay, fuse, or the air pump. He insisted all 3 must me switched out. I asked why they would not switch out the fuse, relay for $55 and recheck the pump.
I insisted they test my pump and get back to me. 3 days later I get a call from my service advisor and told the secondary air pump tested fine. During his research though, he discovered this should have been covered for 7 yrs by MB since this affects emissions. They refunded my money. I wonder how many others have paid to have this replaced???? |
Secondar Air Pump
My 2005 CLK Cab engine warning light also came on and my local Merc shop told me I needed a new secondary air pump - $1,000.
I found this forum and after reading dfishbough's comments, i told them they should check the relay and see if the pump would then function properly - guess what ?? They told me the wire into the relay (or maybe into the pump) was frayed, so they cleaned it up and bingo all's now fine. I have a sneaking suspicion the only real problem was the relay (a $55 part), but they were a bit embarassed that i'd called them out. Still paid the $150 minimum service charge as well, but $200 beats paying $1,000. What a great forum this is - thanks dfishbough !! |
My 2005 E350 warning light came on and my local Merc shop in Kew Melbourne told me I needed a secondary air pump and insisted it was not the relay or fuse when I questioned them. The cost for the secondary air pump in Australia is A$2500 plus labour to install, which seems an incredible mark up compared with $1,000 in US. I did some investigation and found that the part could be imported from Europe for 500 euro which is less A$1000. We may have a few extra import duties but this sort of mark up is ridiculous. Rang a few other Mercedes places and the cost was identical. Is this collusion? Certainly a disgrace and wont be buying another Merc in Australia if this is standard rip off procedure by the dealers.
can any one tell me what is secondary air. code is P0410
I need to know what is secondary air on my 1997 E320. THE CODE READ P0410 can you reply as soon as possible
need help p0410 please!!
I have clk320 p0410 code. I check to see and my air pump does come on at start up. I did a smog test no apparent leaks is there a check vaulve on this model. im thinking of changing the change over valve since its a cheap part. any suggestions would be extremely helpful!
| All times are GMT -5. The time now is 12:00 AM. |
