S430 Is not starting
hello this is Dean! I need help please , Yesterday I went car wash, and after the wash , I came out and my Mercedes 2003 S430 , the signe ESP came and the car turn off by it self, not its not starting and the batter is fully fictioning? what should I do?
water in the car?. passenger side? water flows back to the rear fuse box under the seat and thats where the fuel pump relay is and the fuse box could be wet or under water. check under the hood, right side at the fire wall and see if the cowl drain is filled with water. should be empty.
still not starting
I went and check all the place you mentioned and there was no water! is there a few shot off swatch on these Cars ? the gear does not move, I can't even put it nuetural to move the car ? PLease advise!
I am sorry I meant Fuel shott off Switach?
Now the car started this morning
on dash board the signe came out!
Pre- Safe - inactive/ engine Check signe with Break signe! Please advise! thanks, Dean:) |
| All times are GMT -5. The time now is 08:05 AM. |
