-   -   rear axel (https://mercedesforum.com/forum/general-tech-5/rear-axel-25087/)
hudson Nov 28, 2007 04:33 PM
rear axel
I have a 1985 300SD and amwanting to put a limited slip differential in. I believe that diesels did not comewith them but gas did, does any one know if parts can be swapped to make it work, I know ratios are not the same but maybemy ring and pinion can be swapped in to a limited slip unit and will it fit into my car?Or other suggestions, any one with parts to make this work.
Skip
The snow is getting deeper
