-   -   Raising idle 84 380SL (https://mercedesforum.com/forum/general-tech-5/raising-idle-84-380sl-5797/)
TBenedikt Jul 27, 2005 11:17 AM
I need to raise the idle speed on my 1984 380SL as it is just idling far to low. There are no adjustments that I can see on the linkage so I would assume that adjustments are made at the fuel Distributor. I would appreciate any help that I can get in accomplishing raising the Idle.
Thanks, Tom
shooter Aug 6, 2005 02:08 AM
RE: Raising idle 84 380SL
The idle speed is electronically controlled. The idle acuator or the idle speed controller may be bad. Also check to see if you are getting a closed idle switch at closed throttle.
