Passenger side mirror (park?)
One of the menu options on my SL 55 AMG has an 'on' 'off' selection for the outside mirror when the car is parked. What does this mean? Thanks in advance.
RE: Passenger side mirror (park?)
Well the passengers side mirror will go to a "tilt" feature
when putting the car into reverse, so you can see stuff closer to the ground, note: the passengers side mirror button must be selected for this option to work. It also might be talking about parking the mirrors once you lock the car, which means that the mirrors will "fold in" after you lock the car from the outside. Not sure which one it might be? |
Hello Benztech1. This parking the mirrors option you are talking about do you know if that would be an option on my car? Thanks.
ORIGINAL: benztech1 Well the passengers side mirror will go to a "tilt" feature when putting the car into reverse, so you can see stuff closer to the ground, note: the passengers side mirror button must be selected for this option to work. It also might be talking about parking the mirrors once you lock the car, which means that the mirrors will "fold in" after you lock the car from the outside. Not sure which one it might be? |
no.
yours is manual. |
That stinks!
