OIL PRESSURE W124 W/PHOTOS
Hi, i have two W124 (1986 300E & 1989CE), the 300E was repaired 10.000miles ago (0.5pistons and 0,25 bearing) the 300CE is std 160Km(100K miles).
Both cars have high oil pressure when iscold but the 300E at 80°C dropits pressure to almost 1 while the other (300CE) is still at 3 at the same conditions. If you see the photos, the 300E can reach until number 3 only at 1200RPM and the economyinstrument reaches the lowest mark at this RPM. The other thing, the 300CE is very smoth at idle, while 300E has a little vibration. The 300Eis driving me craizy because most part has been changed to eliminate the idle problem but i´m not satisfy. (rebuilt KE unit, new EHA, new inyectors, new hoses and inyector seals, new idle valve w/hoses, fuel pump (1pc) and fuel pump relay, new rotor, spark plugs and wires, new oxigen sensor, canister vapor. new oil and filter change(semisint. Shell oil 20W50) There is no extranage sound at the valves even hearingwith an stethoscope Whatdo you think is the problem, any suggestion, is the oil pump working bad? [IMG]local://upfiles/26229/CF069D4F9F5F4A4B97CF249010E73B26.jpg[/IMG] [IMG]local://upfiles/26229/072F9AF1FADC456C98F01DE0833C8195.jpg[/IMG] [IMG]local://upfiles/26229/4393051FD163473EAFA0FCA627E467EB.jpg[/IMG] [IMG]local://upfiles/26229/B38EA98DD42A43049CB758017045090F.jpg[/IMG] [IMG]local://upfiles/26229/3415AF15DA8F4DE4A02EEF086C4F0A90.jpg[/IMG] |
RE: OIL PRESSURE W124 W/PHOTOS
Hmmmm..........
My 1989 300E acts just like yours. High pressure (3)when cold but after it warms up it drops to about 1.5 at idle then goes to 3 upon acceleration. Don't think it is an issue. Sounds normal. I have had two instrument clusters in the car and both registered the same. Could it be an oilsensor issue with the 300CE? |
Yes may be...
I will install the 300E oil sensor in the 300CE engine to see what happens (and vice versa) |
I also have a 1989 300ce and my oil pressure gauge is maxed out 95% of the time. It drops down to 1.5 or 2 when I'm decelerating down to 30 MPH.
