-   -   Oil change!!!! (https://mercedesforum.com/forum/general-tech-5/oil-change-13641/)
777nestor Aug 14, 2006 12:48 AM
Oil change!!!!
I have a C230 K. and I took it to Jyffy Lube for its oil change, the problems is they couldn't reset the computer after doing it. So, the computer keeps telling me it has too much oil on it. Does any one knows how to reset the computer???.. the people at J. Lube told me I could do it myself with the owner's manual; problem is I lost mine.
any advices?????
thanks.
C280owner Jun 5, 2007 09:34 PM
RE: Oil change!!!!
first things first, see your oil level yourself and if it goes over max you should take it back to JL and they can take soem oil off till it levels.
I realize you may have solved the problem since the post is old - but I had the same problem with mine at JL. They have a machine that is supposed to tell them the exact amount of oil it should go in.
