NO LOW BEAM LIGHTS ON 96 c280
My C280's low beam lights (both right and left) are not working. I already changed light bulbs and checked fuses. Any suggestions? My high beam work and malfunction indicator is not ON. I pulled a bulb out and it the malfunction light did light up. Please Help!!
RE: NO LOW BEAM LIGHTS ON 96 c280
hey man,
i am sorry to hear this about your car.. replace both headlight sockets that the bulbs plug into and you should be allset to go .. the headlight sockets you need are for 9004/07 ( headlight bulb) series and they run about $ 6-9 a piece.. cut the originals and connect the new ones in the same place and in order.. make sure dont mix the wire connections.. good luck |
