No heat at all coming out from the vents
Old Apr 6, 2006 | 11:52 PM
CLK500KID's Avatar
Default No heat at all coming out from the vents
Hey guys, my brother has an 2003 e500 with 57500 miles on it, just was at the dealer two weeks back for maintance. today i went to take it for a spin and the heat wasnt coming out. the heat is set at high and for about half and hour the heat doesnt come on only the a/c, even as i turn the ac switch off its still blows cold are. what can be the prob
thanks guys
Old Apr 7, 2006 | 01:02 AM
BryanW203's Avatar
Default RE: No heat at all coming out from the vents
Switch over valve by fire wall.
Old Apr 7, 2006 | 07:02 AM
sleepwalker's Avatar
heat exchanger shutoff motor.
they becomes corroded/faulty much easy.
remove the wiper assembly to access it.
Old Apr 7, 2006 | 12:33 PM
bullet proof's Avatar
hey your fan is gone, it's located behind the fire wall, i have a 190e and the same thing happen, but also check your fuses
Old Apr 24, 2006 | 02:43 AM
benzfixer's Avatar
hay buddy, im pretty sure that your 190 dosent have much in common with an e500, there should be a little dial on the center vents that control cold air to the vents, its a mixing control not the air volume control, it controls cold air input to the air stream for what reason i dont know, it scrolls from hot to cold to auto
Old Apr 24, 2006 | 11:07 AM
CLK500KID's Avatar
Thanks for the help guys, but as always sleepwalker is always right, your the man!!!
Jim Cahoe
Jun 4, 2014 09:27 PM
MBZKT
Dec 31, 2010 12:01 AM
rooobpl
Jan 13, 2008 11:07 PM
rooobpl
Jan 12, 2008 05:41 AM
desithrilla
Oct 20, 2007 04:53 PM
