New member, Mercedes-Benz Master Technician
Old Nov 20, 2007 | 07:47 PM
  #31
mbzex's Avatar
Default RE: New member, Mercedes-Benz Master Technician
Hello, I would use the mercedes fluid part # 001 989 21 03 10
you will need around 4 qts...unless you drain the torque converter then you will need about 8 qts.
Old Nov 21, 2007 | 03:57 AM
  #32
livefreeordie's Avatar
ORIGINAL: mbzex
Thanks for the responce i'm greatfull for the help.
Old Nov 26, 2007 | 02:49 AM
  #33
tariqjamal's Avatar
hi guys my name is tariq and I am also a new member inthe forum and i drive( 2002-S320 ) now only 46500km and its in a great condition
but am having a problem with my air matic system at some days not every day morning time going to work i find the front axles both sids is too low level but when i only open the car by the remote control it gos up slowlyto the normal level befor even opening the door.
and if you try toraise the car it dos work perfectly...some of the guys said its air leak and some says its the valveand it was in the dealler workshop two weeks ago and the guys there said that all of the chok apsorbers is allmost new
i will really appreciate it if you could advice me
Old Nov 26, 2007 | 04:48 PM
  #34
mdjmcq2's Avatar
Hi Tony,
Hope you can help. 2006 E350. I got into a war with a deer. Busted my indicator lamp on the pasenger mirror. I have the glass out anr the motor out, can't seem to figure a way to get the lamp out.
Thanks alot, Dave
Old Nov 27, 2007 | 07:48 AM
  #35
jlukas4165's Avatar
Hi Tony, Welcome to the site; I shall be one of the many with questions for you. I drive a 1990 560sel, so far so good. Last week the heat went out on me. I noticed that the temp gage was below the 80C mark, so off I went and replaced the thermostat. Now, when operating at higher speeds, the air temperature blowing out is cold, is there a sensor or something I'm missing? I'd appreciating any help you can give, it's getting cold in northeast Ohio.
Old Dec 2, 2007 | 05:56 PM
  #36
okiemb's Avatar
Hi Tony,
I am a new member here as well. I have a 1988 300 E that has been sitting for about 1.5-2 years. With very few starts. I put a new battery in it and it sounds like it wants to catch when starting but won't catch without some starter spray. I also put clean fuel and fuel treatment in it. My next step was going to be to replace the fuel filter. Can you tell me where it is? I don't see it too plainly. And if you have any other ideas of what to check, I would be very greatful.
Thanks much & Happy Holidays!
Tom
Old Dec 2, 2007 | 06:34 PM
  #37
chassis221's Avatar
back right side under car near rear axle/tire under plastic cover
Old Dec 4, 2007 | 10:40 PM
  #38
fretese's Avatar
Tony,
Simple question, pls help. I want to change the fog light bulb(burned) on the front pasenger side of my clk320. Can you give me and idea how to go for it. Thanks, edgar in NY
Old Dec 8, 2007 | 12:12 PM
  #39
cambo's Avatar
Hi Tony!
I have a question for you. I own a 1979 240D which needs axle joint boots; however, I've discovered I can replace the complete axle assmblies cheaper. I've searched and found on parts websites there are two types of axles for my car, a 8mm homokinetic joint axle and an annular joint axle. I think there is some type of modification I have to make in order to use the annular joint axle; however i'm not sure and I'm not sure what the modification is. The 8mm homokinetic joint axles are in the $125 range and the annular joint axles are in the $405 range. $125 sounds really cheap, in your opinion, is it a quality product or a piece of junk. Thanks in advance for any insight you may give to me.
Cambo
Old Dec 11, 2007 | 12:36 PM
  #40
JD60's Avatar
New today.
Hi Tony, can I link you to my query: https://mercedesforum.com/m_90102/tm.htm
[align=left] [/align]
