Mercedes GLK 220
I got this DTc codes, can sombody hep because I don't have the documentation
P0244 P0A16 P244A P2626 P2A00 THANKS |
You're able to find these codes and their meaning in Google.
P0244 is an OBD-II generic code indicating that the engine control module (ECM) detected the Turbocharger Wastegate Solenoid A input circuit range or performance to be out-of-specifications when compared to the turbo boost sensor, manifold pressure sensor (MAP), or the barometric pressure sensor (BARO) at idle. |
