Int. Door Panel Removal, 2nd Try!
I searched for this and didn't find what I need so,
I need to remove the front door panel (1985 190D) for window replacement. I took the 10mm bolt out of the pull handle and removed the trim from the door latch. I'm trying to be careful so I don't break anything. With gentle upward pressure, the panel wants to move but it's tight where the power seat switch assembly is. Is there a hidden screw I'm missing, or is there a "trick"?
I will also need to remove the rear panel, too. Any mystery there?
Ken
Ken
RE: Int. Door Panel Removal, 2nd Try!
Hi there,
I think you need to remove the door grip handle so that you can slide the door release handle plastic trim forward so it comes un-hooked. Then you should be able to push the door liner upward to un-clip it from the door. Also you need to remove the plastic trim at the latch.
Same thing on the rear doors.
Good luck!
Good luck!
To be clear, for anyone searching this string for an answer....
Remove the screw and trim on the door latch
Remove the 10mm bolt that's under the top plastic trim on the grip handle
Remove the 2 phillips head screws from the seat switches
Push plastic trim thats behind the door release handle forward
lft the pannel upwards
There you have it....
Johnny Thundereagle
05-28-2009 10:53 AM
