installing wis
Dear Boss
please could anyone help me with a prob i have installing wis on my PC and evry thing is ok till wis installed .then whene i'm going to open it it works with german language .since i'm i have installing it with english . pls i want anyone to help me and send me the statements to install with and operate it with english language also for inform when i'm installing wis i was offline from internet is this true or false? b.regards H.Gemaiy |
RE: installing wis
I am not the best person to help you with this. I have only recently installed wis and have not been completely successful. However, there is a lot of information available if you go to Search and write in "wis install". I believe I recall someone there who had a problem similar to yours.
ehuff |
RE: installing wis
Start WIS and go true the menues to change the language.
It is called somethink like SPRAWEHEN. My german is not good :) |
RE: installing wis
Yes, that could be the problem. The language part of the Windows is on mycomputer. Also, did gamaiy00 do a clean install? or install over another version? If it was a clean install, that is no other OS was on the PC then it could be a mulitude of problems. If it was an update from a older OS, if it was formatted correctly to start off with, I would reboot with the CD and start all over again.
