-   -   Help...removing a right front axle from E500 4matic??? (https://mercedesforum.com/forum/general-tech-5/help-removing-right-front-axle-e500-4matic-14731/)
kenhiggs Sep 28, 2006 01:34 AM
Hello,
Does anyone know how to remove a right front axle from an E500 4matic? It's a 2004 model. Any help or direction would be greatly appreciated.
KenHiggs
Katniip26 Aug 16, 2022 10:03 PM
Try this
Try removing the front right motor mount and that should give u enough space to wedge a pry bar in behind the inner cv joint housing to pry it off the engine block. Just make sure to use a brass punch to reinstall ur axle instead of just using a hammer. Brass is a much soft metal and it won't damage the metal that the axle is made of. Hope this helps.
CHEERS!
Originally Posted by kenhiggs (Post 57299)
Hello,
KenHiggs
