HELP NEEDED - BMW
Guys - Help is needed. My BMW '97; 540i will start and after less than 2 minutes, it will shut off. Sometimes, the 'oil change' light will be ON but now it is ON and will not go off. I top up the engine oil and coolant and these do not help. I bought the car about a year ago and never tune-up the engine. Apart from the latter statement, the car has been running great.
Any suggestions. Please help.[8D] |
RE: HELP NEEDED - BMW
the 'oil change' light try to reset it twice (jumper on terminal 1 & 7 for more than 10 seconds. will start and after less than 2 minutes, it will shut off. |
[/quote] you mean the green LED? Yes Sleepwalker. [quote] jumper on terminal 1 & 7 for more than 10 seconds. CAN YOU TELL ME WHAT YOU MEAN BY JUMPER ON TERMINAL 1 & 7 AND WHERE TO FIND IT? [quote] replace the fuel filter. WHERE IS THE FUEL FILTER? Thank you |
Try bimmerforums.com, they can be very dick but definatly know what they're talking about.
bimmerforums.com is not as helpful as mercedesforum.com.
Sometimes, it takes forever to get assistance on the bimmerforum. Many experts in foreign cars on this website than others and you will agree with me. |
Guys - the fuel filter is under the vehicle, driver side & below the trunk area. Above driver side of rear axle and it is mounted on the frame.
Still need help - WHAT YOU MEAN BY JUMPER ON TERMINAL 1 & 7 AND WHERE TO FIND IT? Thanks |
Thanks Sleepwalker. I changed the fuel filter. So far so good, the engine does not stop like before. Since changing the fuel filter, the situation happened only twice. I am still afraid to take the car on a long trip.
I put in gas treatment, maybe it will also help. Can you tell me where to find the "jumper on terminal 1 & 7? |
gee, I thoguth tha this was mercedesforum.com, not bmwforum.com
from diagnosis plug.
clean the idle speed actuator. spray good amount of carburetor cleaner few times. must remove it to clean. [IMG]local://upfiles/1/2335BF0B70B3405E9C6CC425E49B96C5.jpg[/IMG] |
