Help, With Mercedes R350
I have a 2006 Mercedes Benz-R350, has 79k miles. The check engine light is on and cannot pass State Inspection. Can anyone help me find what the problem is? If it is a sensor or a part where can I find it? How can I change it? In the bottom you will find all the information that I have from my OBDII reader! The check engine light is on because of two codes Code Type Status Description P2187—PowerTrain—System Too Lean at Idle P2189—PowerTrain—System Too Lean at Idle Also: Fuel System Monitor Bank 1 TID $80 - Manufacturer Defined 6 -4.5 4.5 % Fail Fuel System Monitor Bank 1 TID $82 - Manufacturer Defined 1.1323 0.6996 1.2992 Pass Fuel System Monitor Bank 2 TID $80 - Manufacturer Defined 6 -4.5 4.5 % Fail Fuel System Monitor Bank 2 TID $82 - Manufacturer Defined 1.1224 0.6996 1.2992 Pass Need help asap please! :( Thanks |
| All times are GMT -5. The time now is 08:39 AM. |
