help!!!!
hey wazz supp guys my name is jay and im new to this so is if someone out there knows aboutmercedez please help me out its a ml320 ,year 2000....alright my first plroblem is that on my dash it indicated that im over-4000 miles?..how do i get thiserased or maybe if theres a reset button somewhere?....my second problem ishow hard is it to change the fulid on my transmission?......i haved done all spark plugs change and aswell the oil change!....someone please help....it would be appreciated!..thanks.
RE: help!!!!
Hey, welcome jay.
The warning on your display has to be reset by a diagnostic computer so you will probably have to quiry your local dealer for that. Your transmission is a 722.662 and Mercedes has their own formula for the fluid so you may again have to get this from the dealer. Changing the filter and fluid is pretty straight forward with the lions share of the fluid in the torque converter but their should be a drain plug in the converter so you can get it all out. Most Dealers like to replace the filter and pan screws so you might want to check availability on those before you start. |
