G320 or G350
Hi, i have recently bought a 1982 chaisses of G280, i was thinking of transforming the chaisses into a fully loaded G class of a newer model i.e 2006 to 2008.
i am stuck between which engine to install as i am concerned about fuel efficiency and power taking into consideration the heavy weight of the G wagon. I have also looked up the CDI engines, however given the quality of diesel in where i reside it will be rather problematic to install such advanced engine. I am in great need for an expert advice with regards to: Which is better engine and less complicated which less fuel consumption is it the 320 or 350? will this transformation work fine on an old chaises noting that i will change everything expect the chaisses, i.e i will mount a new/used wagon on to the existing chaisses. your feed back will be highly appreciated, and i hope you accept me as a new member on your great forum. |
| All times are GMT -5. The time now is 09:45 AM. |
