Fuel filter location on SLK
Hi</P>
Had to come all the way to the states tofind the answer tothis question...Mercedes seems less than helpful to Individuals servicing their cars.</P>
Where is the Fuel filter located on a 1999 SLK, any tips to changing it?</P>
Is there a pollen filter on same car? if so where and again any tips on changing it?</P>
Thanks in advance</P>
come on guys surely someone can help me out with this quicky?? Also does the car have a pollen filter, the guy at my shop was saying if it has aircon it doesnt have a pollen filter?</P>
I have a '97E320, have owned it for3 years and haven't found the fuel filter, pollen filter or the activated charcoal filter that Mercedes has tried to get me to replace everytime I've taken it in for service past 60,000. Any help out there? <edited><editID>Paul</editID><editDate>37987.1269212963</editDate></edited>
Sound likeeasy questions to answer. I wish I knew. I'll pop it backto thetop for you.</P>
I can't help wondering, though, what you're doing in Afghanistan with an SLK, and what is a MB dealership doing in Afghanistan? You're obviously not a native. Does your SLKsport any bullet holes?Are you armed and dangerous? Did the USA bomb everything but the MB dealership?</P><edited><editID>Lugnut</editID><editDate>37992.2940393519</editDate></edited>
Err sorry not sure how I ended up with my profile showing me as from Afgahnistan!!!!! Actually from the UK, just north of London.</P>
Well I found the activated charcoal/pollen filter...its one and the same. In the SLK its behind the glovebox. Just remove the panel underneath the glove box (its easy 2 screws) and you will see some ducting, in the middle there is the filter, which can be accessed by sliding 2 clips allowing the cover and the filter to drop out of its housing, just remember which way round it went for the replacement!! Takes about 10 minutes to do and is a piece of cake......Now that fuel filter anyone???</P>
<DIV><SPAN class=067012710-10022004><FONT face=Arial color=#0000ff size=2><SPAN class=067012710-10022004>Spent 2 hours under my SLK 1999 last night trying tofind the fuel filter, managed to find it (eventually) one thing stopped me taking it off though...I wasnt sure how the clips that hold the rubber pipes to it work or even if they can be re used, it almost looks like they are crimped into place. Anyone got any ideas/experience with these clips??</SPAN></FONT></SPAN></DIV>
the clips are reusable but only with special tool available though high end tool </P>
dealers take a pair of side cutters (dykes or wire cutters and remove the clips replace them with regular screw type clamps u will need 3 or 4 of them available at the local hardware store</P>
