fault code, OM906LA engine
For Benz OM906LA electronic controlled diesel engine, the diagnosis connector are 14 pins, and only 5 pins are useful.
My question is how to trigger the fault code manually, for example, to connect some pins, then the system can flash code on dashboard. I am in china, in many areas, there aren't Benz service stations, and not so many customers/service stations can afford Star or Mini-diag. Thank you very much in advance. |
RE: fault code, OM906LA engine
give me the chassis number.
you are talking of transporter or truck...right? i am in wenzhou and got everything you need, HHT or Star Diagnosis. i was in Daimler-Chrysler beijing for quite sometime doing ACTROS and ATEGO, i can help you. |
ok, maybe you are talking of industrial engine also and chassis number is not possible.
i still got all the informations. just tell me the 6 digits engine number. 906.900 - to - 906.989 |
I have a stardiagnosis but I don"t have accece to use fdoc system how i can relearn the key transponder Thanks
HI
I want ask pleas for ACTROS transponder key how to relearn without FDOK accese |
Originally Posted by shary
(Post 100132)
Hi
I want to know where i can find the description and solution of codes that there aren't in the manual. Saludos form Mexico! |
I want to know why my Atego 815 is showing code on the display panel.And when you turn the key to the start position the starter keeps running with key turned off.Engine does not start.Engine number OM9044A.Chassiss number is WDB9700272K454163.
Fdoc access
(Post 100132)
i have a stardiagnosis but i don"t have accece to use fdoc system how i can relearn the key transponder thanks
am also having the same problem, having the stardiag and i cant relearn the key transponder of my axor truck which lost its key. Kindly help. Thx in adv. |
Originally Posted by sleepwalker
(Post 8646)
you are talking of transporter or truck...right? i am in wenzhou and got everything you need, HHT or Star Diagnosis. i was in Daimler-Chrysler beijing for quite sometime doing ACTROS and ATEGO, i can help you. kindly help. |
