False diagnostic codes 2008 ML-320 CDI
Old May 1, 2017 | 03:08 AM
Dave Waddell's Avatar
Default False diagnostic codes 2008 ML-320 CDI
I have had issues with the right rear turn signal saying it was out (especially in the colder weather) even though it still works with the emergency lights (I can also fix it by removing and reinstalling the bulb). I also had a P0672 (#2 glow plug) which returned even after I replaced the (what turned out to be a functional) glow plug. I reset the error code with my OBDII scanner but it came back a couple of hours later. I also have an error with brake wear which is also false. These are all sensors that might be considered resistive. Could these problems be related and caused by another common sensor that determines resistance, perhaps?
Old May 4, 2017 | 04:16 PM
That seems unlikely as the error codes occur before the engine is even running.
Thanks, Dave
dieselburner
Nov 5, 2011 11:56 PM
Joy
Sep 23, 2008 09:33 AM
Joy
May 16, 2008 09:24 PM
97dmsrS420
Sep 6, 2006 12:09 PM
BlackWolf
Feb 22, 2006 09:22 PM
