-   -   electric windows 1982 380sl (https://mercedesforum.com/forum/general-tech-5/electric-windows-1982-380sl-14214/)
Sandi Sep 5, 2006 11:11 PM
Both electric windows simply stopped working. The fuse checks out ok. Any suggestions? Thanks
snanceki Sep 6, 2006 03:36 AM
RE: electric windows 1982 380sl
BOTH (LH and RH?) simultaneously!
Sure you got the correct fuse? this is the only component common to both circuits that I can think of.
If you are DIY competent check voltage at each end of the (correct) fuse to ensure the supply is OK.
If this is OK you will have to measure voltage at various points in the circuit. next suspects are SWITCHES and RELAYS but two circuits would not normally go down together.
Stuart
