-   -   Drivers side door controls - HELP! (https://mercedesforum.com/forum/general-tech-5/drivers-side-door-controls-help-30405/)
tomard Jun 28, 2008 06:48 PM
All of my drivers side controls on 2000 S430, such as power windows, power mirrors, seat adjustments, everything, has stopped working and does not appear to have any power!!! I checked fuses and don't think it is any of the f## fuses ..... does anyone have any idea where to look (fuses again, or ???)
There are no lights or any indication of power to anything on drivers side, EXCEPT door still locks/unlocks with remote. Passenger side everything works and lights up.
BLUETEAM Jul 1, 2008 11:52 AM
RE: Drivers side door controls - HELP!
FUSE 13 IN THE LEFT FRONT FUSE BOX IS THE ONLY FUSE USED FOR THE DCM.
tomard Jul 1, 2008 08:15 PM
Checked the fuse 14 again (40amp) .... even replaced it to make sure .... still NO power to door, except for auto door locks!
BLUETEAM Jul 2, 2008 11:21 AM
FUSE 13 NOT 14. YOU SAY YOU HAVE NO POWER TO THE DOOR. HAVE YOU CHECKED WITH A MULTIMETER OR YOU SAY THAT BECAUSE NOTHING WORKS? PULL THE DOOR PANEL, REMOVE CONNECTOR 1 FROM THE DOOR CONTROL MODULE AND CHECK FOR VOLTAGE BETWEEN PINS 1 AND 2 WITH 1 BEING THE GROUND.
tomard Jul 5, 2008 07:43 AM
I had the door panel ALMOST all the way off, something still holding it on down by handle that I don't see what it is .... had to go out of town so I put it all back together ....
Will check fuse 13 today.
tomard Jul 8, 2008 07:48 AM
Will have time to check f13 today ..... also found out that my girlfriend had left window open one night and it rained hard and everything got wet ......
No power to anything, is why I say nothing is working! Have not gotten inside (almost did but couldn't get bottom of DCM to come out), something down by door handles holding it in ...... Will update after I check f13
tomard Jul 8, 2008 11:02 AM
f13 (40amp) is good, replaced it anyway, just to make sure and still no power to anything.
BLUETEAM Jul 8, 2008 03:16 PM
WATER = BAD CONTROL MODULE.
tomard Jul 8, 2008 03:29 PM
Any idea of how much $$$$ to replace it?
